Hays Co. TX + San Marcos + LCRA
chadbyoung
Austin, Tx
Hello All
Does anyone know what radio's are used by the San Marcos PD? How about the radio's used by the Hays Co. EMS use?
Thanks, Chad
rattlerbb01
TX/LA Database Admin
Boerne, Texas
chadbyoung said:
Hello All
Thanks, Chad
You look like you already have the answer in the title. :D
They are on the LCRA system. Quite a few talkgroups for both of them as well. If you aren't familiar with the system, it is an EDACS standard networked system on 900 MHz. You can program both sites in Hays County into your scanner, if it does EDACS trunking, and listen away.
bpckty1
Well, out of curiosity, to continue a bit on the radio question, what radio brand(s) do they use?
pacrat551
TX Admin
Texas
chadbyoung said:
Hello All
Thanks, Chad
I believe they are using the Ericcson LPE-200. I think that is the correct model number that most of the agencies are using. I've only seen one other model that was older and I didn't catch the number on it
justin624
Most agencies with EDACS systems are moving over to Jaguar portables (M/A-Com radios)
chadbyoung
Austin, Tx
Doohhh!!
Thank you - I did ask that question wrong. I wanted to know what radio model thet carry.
Chad
kiddy911
I'm new and don't know what to do but I would like to get the scanner frequencies for san marcos and hats county. Help?????????
kiddy911
I'm new and I wonder if anyone has the frequencies for san marcos and hays county. help???????
musicman476
RR DB Admin
McKinney, Texas
First, it's not necessary to post the same question twice in a row. Once is fine. :)
All the info you need can be found in the Database here. Click on the Database link at the top of your screen, then click on Texas on the map. Scroll down and click on Hays county. You will need to program the LCRA system to hear San Marcos.
Montz816
Emergency Communications
Kyle TX
I live in the Kyle area and would be happy to set you up but the only other question would be what type of radio you have?
Montz816
Kyle TX
also we do use the M/A Com LPE-200 and the older radio that was referred to is the G/E MRK which is a great radio it stands up to MIL-SPEC standards and keeps on trucking.
or keeps on 'trunking'
RaymondRenteria
San Marcos
needing an ericsson lpe200 900mhz program or clone
Hey I live in Kyle as well,and I bought an Ericsson 900mhz lpe200 off of ebay,I'm not sure if u know how to program it, I know there's a way to clone from one radio to the other, is there a way u can help me out, oh and I also bought an Ericsson Orion mobile base radio that has a built in desk top. My email is mustan78666@yahoo.com please let me know if u can help me out.
texasemt13
CenTex DBA
Hunter, TX
Montz wouldn't be able to help you without potentially risking his job (as far as I know).
If you'd like to talk about programming your LPE200, send me a private message. I have no experience with the Orions.
