HDSDR Help
millam
Old Radio Guy
I have SDR# running, I lucked out on the first install it seems. But I can't get HDSDR going. The extra
step of adding the dll stumps me. I need to know when to do the following things:
1. When to install HDSDR?
2. When to run Zadig?
3. When to run the dll software? Where to put it? Automatic?
4. When to plug in the receiver?
5. When to start HDSDR?
SDR# is ok but having to reload freqs if I stop and play, no presets, etc., I would like to compare and see
if I prefer one over the other.
System is Vista on an old hp laptop.
Note: When I use a EDA 2100 drop amp I see no noticeable difference change, maybe a slight
rise in noise level. I assume that the agc kicks in and reduces gain with stronger signals.
Mil
millam
Old Radio Guy
n9mxq: That link has been broke for me for the last day or two. I had it bookmarked earlier but
it wont work for me now. If it does for u let me know ok.
Mil
n9mxq
Belvidere IL
Mil
Not working here either.. Didn't check it before.. hehe
If I remember right you install HDSDR, run Zadig (I used all the default install settings), then run HDSDR as normal.
millam
Old Radio Guy
Got it going.
https://www.thecraag.com/RTL-SDR_on_Windows
step 5 I didn't have to do, I think
step 6 hint was wrong should be RTL readlen=8192 tuner=e4k
HDSDR is more sensitive, noise level below 100, SDR# noise level around 85.
HDSDR presets great, SDR# have to reset every time you change / load.
SDR# waterfall bigger.
SDR# 2 meg display ~~ HDSDR < meg ~~ kinda sorta
Mil
