Headless Spectras
Project25_MASTR
Millennial Graying OBT Guy
Texas
I probably have 12 or 14 high power spectra radios sitting in a storage shed. Mix of vhf and uhf but I don't have any heads. I'm just assuming that they are just for door stops without the heads...would that be a correct assumption?
jim202
New Orleans region
Have you taken a look at the following site?
Batboard • Index page
You will be required to register on the site, but there is a ton of information there and many that will help with problems.
cmdrwill
So Cali
Doorstops... I hope not. We can use them out here.
FYI, there is a test connector that allows a Spectra to run without a control head. Just can not program a radio that uses a A9 head. We use the test connector to isolate problems.
brndnstffrd
CT
Control heads are cheap and fairly common. If you dont want them, there are lots of people who would be interested, and maybe you could make a couple bucks over just tossing them in the dumpster.
zz0468
...I'm just assuming that they are just for door stops without the heads...would that be a correct assumption?
As stated, no, that would be an incorrect assumption. For certain applications, Spectras can be made to run just fine without a head. But if a head and cables are actually needed, that's what eBay is for. There is no shortage, real or perceived, of Motorola Spectra parts and accessories available on the 'net.
mikewazowski
Forums Manager
Oot and Aboot
Headless Spectra's make great APRS or control channel decoding radios.
Project25_MASTR
Texas
I actually found a lot of 8 A9 heads for $40 on ebay…just need some control cables and I'll be in business. How would you set them up for APRS without the head?
mikewazowski
Forums Manager
Oot and Aboot
Guys, before it gets out of hand, a reminder that Buy, Trade and Sell cannot be conducted in the regular forums.
