Heads up Little Rock and Memphis ATC
VernM
Arkansas' Ozarks
Didn;t catch the call, but an aircraft, likely airline, has just called Memphis/Little Rrock to declare an emergency and ask for the longest runway available. Problem is stuck flap, he said. Time is 2030 UTC 09/08
Colin9690
Delaware County, OH
Lewis Center, OH
Should be a pretty benign issue. Since flaps are used during landing, it shouldn't be too hard with the flaps already down, like they should be for landing. Only issue is if it's only one flap that's stuck, then it would create an inbalance.
rbts
The flap setting is not just up and down. There's several flap settings for most aircraft.
Sometimes the flaps fail at a setting other than the one needed for landing. When that happens, we get data from a quick reference handbook to adjust landing distance needed to land and stop based on landing weight. Flight crews have to adjust approach speeds, again based on landing weight, to compensate for the particular flap setting where the flaps failed.
Faster approach speeds and longer distance needed to touch down and stop are usually not issues with dry, uncontaminated runways. If there is snow, ice, slush or standing water then a flaps fail can turn into a mess very quickly and might involve a diversion to an airport with longer runways.
Obviously, Boeing's and Airbus' are going to need more runway than CRJ's, ERJ's and turboprop aircraft if their flaps fail. It's all based on estimated landing weight.
mancow
N.E. Kansas
I remember flying in a 1940's Aircoupe with a friend. The concept of flaps there consisted of sticking your hands up over the windscreen. :p
