Headset for TK780
deputywhit
Washington NC
I run a fire dozer and I need a headset to fit my TK780 I was hoping for somethong that direct plugs in to mike plug? any ideas would be great Thank you
There's a KCT-19 accessory cable for these radios that will give you an external audio/mic/PTT connection point.
It'll require some reprogramming of the radio to make it work correctly.
As for the front RJ-45 connector, not sure Kenwood ever made one, I've never seen it if they did. You might have to search for third party manufacturers. I know the products are out there for the racing community.
Here's a discussion on the TK-760: http://forums.radioreference.com/kenwood-forum/281857-kenwood-tk-760-david-clark-headsets.html
I think you may need to use the KCT-19 cable off the rear of the radio to do this right. I did a quick look at the service manual and I don't see that the RJ-45 on the front of the radio has the speaker audio there.
deputywhit
Washington NC
the RJ45 has no speaker connections so could I make a cable that uses RJ45 for mic and PTT and plug into ext. speaker plug for those? I want to use this head set on any of our Dozers so I don't want to modify radio in each one
That would probably work fine.
Drawback will be that you'll have to have the headset on to hear any radio traffic. May not be a good choice if you stop for lunch, pee break, etc.
The beauty of using the rear connector is that you'll retain your speaker for when you take the headset off.
deputywhit
Washington NC
Our dozers already have external speakers so I was going to add an extra plug on mine and just unplug if on another dozer .I also carry my portable on my chest harness but want the transmit power of the mobile radio.
Got it, that would work.
The microphone and PTT connection is obviously on the RJ-45, so you'd be good there.
What you need to find is a microphone that has the correct impedance.
That's an older radio, so it may be difficult to find accessories that are specifically sold for it. Kenwood does not sell a headset that will interface to the mobiles, so you'll have to go after market.
David Clark makes an off the shelf solution. It will be expensive, but DC is a big name and it's probably well worth the price.
Check here for your solution:
Two-Way Solutions | David Clark Company | Worcester, MA
ramal121
Lots and lots of watts
Calif Whine Country
If the radios use an external speaker that plugs into the 3.5 mm jack on the back, you could get a "Y" adapter and have both the headset receive and speaker going at the same time. Easy enough to remove and return speaker to the way it was.
deputywhit
Washington NC
That is the plan as of now. the other issue I have is my headset has an M3 connector and I dont want to change that so I am going to find an old HT1000 and use the case to built the adatper. That way I can just connect headset to HT1000 and should be good to go. Just need to open up HT1000 and connect wires inside to connector. If all goes well.
ramal121
Calif Whine Country
Well OK, sounds like a project to me. Good luck. Just make sure the headset has a mic element compatible with the Kenwoods. This would be a dynamic mic, not a electret or condenser type.
If you run into a snag, holler. Somebody should be able to help.
