I've seen quite a bit of 11 meter SSB digital activity in Europe using the pskreporter web site. Display Reception Reports They all appear to be using a digital mode called JS8. (It's legal there).
JS8CAll is similar to FT8, but it has the capability of keyboard to keyboard chatting. In order to use the mode, you require an SSB radio, a transmit/receive audio interface, computer control of RX/TX and a software program called JS8Call. JS8Call
So.. today just for fun, I fired up JS8Call connected it to my IC-7600 radio tuned it to 27.245 MHz and pointed my beam to Europe. I left the radio on for the whole day. Darned if I didn't manage to pick up two stations.. 10MEX105 in Mexico and YRM63DLVK in Romania.
Since you need a computer to run JS8. If you're connected to the internet, you can tell the JS8 software to report contacts to the pskreporter web site over the internet connection. Contacts appear as 'pins' on the site. They show who is hearing who and even connect lines between the pins.
In the image below you can see the pin for YRM63DLVK and a line over to me where it says 4 hrs.. (Which was the time since I last heard him). The image below that shows the JS8Call screen with the two stations heard in the right hand 'callsigns' box.
Note that the signal report of -17 dB is down in the noise floor. Signals that weak can't be heard in the speaker, but the weak signal capability of the software managed to 'pull it out'.
What does this mean? Not much. I don't have transmit capability. Even if I did, it can't be done legally in the US or Canada. I just did it to see if I could snag a European station or two.
