Hearing control channel while scanning system
Rich83
Missouri
I have a BR330T and while scanning some Motorola systems every now and again when someone transmits it seems to get stuck on the control channel i.e you can hear the data being streamed. This seems to happen on a certain talk group. I had a quick play about with end codes but its not seemed to change anything. Is this a problem with their system or my scanner ?
loumaag
Silent Key - Aug 2014
Katy, TX
Moved to the General Scanning forum. This has nothing to do with Trunking Decoding.
N8IAA
Fortunately, GA
What systems? How are you programming the scanner? It sounds like you may have to tweek some settings on the scanner.
Larry
sjlamb
Sarasota County, FL
It sounds like that which happens when you get on the very fringe of a particular site's effective range. Sometimes locks on and decodes; other times a short data burst before decoding or a short data burst and then resumes scanning.
Rich83
Missouri
that maybe the case, Iv had that system in my scanner for months and Iv never had a problem. I have moved about 9miles and usually its pretty good occasionally it happens. It just made me wonder because have have updated some system recently and wondered if something got altered that I hadnt noticed
sjlamb
Sarasota County, FL
Typical trunked systems are designed to reliably "reach out" approx. 12-15 miles. Many other factors can and will affect your actual results but, figuring out how many "air miles" you are from the site in question should give you an idea of what to expect. The fact that a recent move 9 miles further from the site coincides with this issue is more than a bit suspicious.
