what scanner codes will allow me to listen to everything in the county? i am forced to use the app bc i believe i am missing some.... thanks in advance
well depends on where you live in Schuylkill Co they operate off alot of different towers because of the hills and valleys. Used live in Tamaqua and hearing the rest of the county unless had external antenna.. Fire is 46.5800mhz for that area and didnt work that great when ran with fire dept. Everything on RR Database is correct you just need to play around with placing your scanner in right location..
