Help-Baofeng UV-82HP Questions
Kaitfl
I recently purchased the Baofeng UV-82HP which has the following frequency ranges:
136-174 MHz (VHF)
400-520MHz (UHF)
A mature (Part 97) Usage
I am curious if there is a way to get frequencies in the 700-850 range. If so, what do I need to do/buy? The channels id like to listen to are mostly in the 810-850 range. Thanks.
ko6jw_2
Santa Ynez, CA
The Baofeng will not receive 700-850 and no model they make will do so. I suggest getting a good scanner that will cover that range. Baofengs make poor scanners. They scan slowly and receive only analog FM. No aircraft AM, no digital, no trunking. I have a couple for back up/throw away ham radios, but a dedicated scanner will be much better. Unfortunately also more expensive. Which one to get will depend on where you live and the types of systems you want to monitor.
SteveSimpkin
Lancaster, CA
As mentioned above, your Baofeng radio will not tune up that high in frequency.
In the US, it is illegal to sell scanners which cover the old analog cellular phone frequency bands in the 800 Mhz range. For scanners sold in the US, this is the typical range of frequencies covered in the 700-900 Mhz range.
Uniden
758-824 MHz
849-869 MHz
894-960 MHz
Whistler
764-824 MHz
849-869 MHz
896-960 MHz
What country are you located in?
