O
opp37
Guest
im going to make a tower in the summer for my antenna
its one of those home maid pipe bomb looking thing works great for me
anyway its tiny so i thought a 2in pvc pipe or two
its cheap and lighting shouldn't be after it
but then i realize if i put two of those long pvc together how the heck will i support it and keep the wind and stuff from taking it out
the rest is easy im using high grade rg6 straight run to scanner with no breaks except antenna to cable and thinking about shrink tubing that connection i dont know if a open connection matters but i want the best reception thats why im using compression bnc connectors i always use compression i was a satellite installer and got most of my customers a 99 out of 100
i have seen and know the build towers but expensive when on very tight budget like 30 40 bucks cable is going to put way over enough
any help ideas any thing im missing or do you just think im a dumb moron
