rolypolyman
This post is the culmination of two years of aggravation with P25 decodes on FMP24 (the paid version) and I am at the end of my rope. I am monitoring a municipal police repeater only 1/2 mile away. It is an extremely simple system that has all traffic one frequency, no control channel or anything, so reception is just purely decoding the P25 signal. As you can see from the screenshot I'm getting a good strong radio signal and the receiver is locked.
About 50% of the transmissions are good, but for the other 50% I get choppy and stuttering audio, from both dispatch and from their mobile units. I don't notice any particular pattern to it. The parties on the frequency all seem to hear each other fine. It sounds similar to what you might hear on an analog radio when the squelch is turned up a little too high. Squelch is not enabled, I checked by pressing Q, verifying it came on, then turning it off.
I am using a SDR Blog DSD receiver. Data is being fed from FMP24 to DSDPlus via "Direct FMPx linking" (port 20002). I have noise filter and shaping filter both off, and it has no effect either way. I have tried decoding with those filters on with similar results. In the menu tree I have all the decodes disabled except for P25. CPU use for DSDPlus.exe is 0.2% while idle and 1.1% while decoding, and for FMP24.exe it is consistently 1-2%.
The baseband raw file is here: fmp24_decode_error.zip (70.22MB) - SendSpace.com (75 MB ZIP) and it includes sample audio WAV files.
Can someone test the baseband file and let me know whether they're getting good decodes? I don't know what to do at this point or if there's a setting I'm missing.
