Nope..that didn't work. Don Starr...can you lend any help on this one ?MacombMonitor said:As I recall, you can open both programs, then highlight the data in one, and paste it into the other.
That's correct...you CAN copy data from WIN95 into WIN97. However, I need to do the reverse...which does not seem to work. Any suggestions ??OkRob said:I have copied and pasted data from rows in Win95 and pasted them into Win97, so it will work. Might just have to try it a time or two to see what will make it work, but I know that it will work. I have copied all rows from the channels side and pasted as well as copying all the talkgroups in a bank and pasting them as well. Saved me alot of time in setting up a Win97 file like I wanted it.
- Rob
jeff2233 said:That's correct...you CAN copy data from WIN95 into WIN97. However, I need to do the reverse...which does not seem to work. Any suggestions ??
Win95 does not import CSV files.ka3jjz said:I haven't tried this but my first thought is to dump the 97 data into a .csv file, then import it into Win95. I have a feeling you'd need to edit out the data that the 95 cannot use, such as PL or DCS information, but that should be easy enough, if a bit tedious. 73s Mike
I tried copying my WIN97 data into WIN95..and t only takes ONE line at a time. How do I save my WIN97 data as a csv file so I can import it to WIN95 ??scnnr said:I know this is going to sound like a lot of work but it worked for me. I imported my p97 file as a csv file to Win 96 then opened up win 96 to copy and paste to win 95.
I don't know why it won't copy and past frm win 97 to 95 but it will copy and past from win 96 to 95. Sooooo, :roll: if you have Win 96 as well you could try that.
Randy
jeff2233 said:How do I save my WIN97 data as a csv file so I can import it to WIN95 ??
loumaag said:Win95 does not import CSV files.
He has never said he has Win96. And if he had tried it out sometime previously the timed free tryout period may have expired.scnnr said:I guess maybe I never made it quite clear. What I did was this
