dfw1193
The topic in the Manual: Creating a Favorites List from the Database
The specific verbage I need help with:
The easiest way to create a list is to select(or turn off) any Nationwide Systems then use Add Channels
On Range to specify a location, set the range, and the service types you want to listen to, and import
channels from the full database to a new list.
What I have done:
Using sentinel I have:
1. Created a new profile called Range50
2. Using the profile editor I have edited the Range50 profile as listed.
a: Service Types all selected
b: Location setting I have entered a zipcode 76063
c: I have set range to 50.0
d: I have checked on the Scan Selection Monitor Full Database and unchecked with no result difference
e: Under Scan Selection I have turned on Download and turned on Monitor
I have tried the following:
Under Edit I have picked Add Channels on Range once again entering the zip code 76063
Also selecting the profile again when asked Range 50
The program message "Finished appending channesl on the range to favorites list"
But nothing was added to the favorites list when I checked by using Edit favorites list
Under Edit favorite lists / options I have
a: Location control YES
b: Startup Config Key 9 selected.
MY THOUGHTS:
I wanted the sentinnel to create a favorites list I named to include all monitorable frequencies/systems etc. within a 50 mile range centered on zip code 76063.
Why is the software not doing this?
I reread the verbage listed above and could not find an IMPORT from full database option anywhere.
Someone please explain how I can create a favorites list based on the 50 mile location of zip 76063 please.
I am at a loss ... I have created many favorites lists by manually finding and appending the systems etc. to a favorites list from a state file and wanted now to create multiple Range ## favorites lists against the full database based on range to a zip location.
Any help is appreciated.
Wayne in Texas
What I have done:
MY THOUGHTS:
Wayne in Texas
