HELP: DSDPLus Fastlane decoding 2 control channels
apx70001
Humboldt, IA
I have DSDPLus Fastlane working on a Phase II system using ONE Nooelec NESDR SMArt SDR. Can you give me guidance on running a 2nd DSDPLus Fastlane program using a 2nd Nooelec NESDR SMArt SDR and 2nd monitor set up for monitoring a 2nd control channel from the SAME computer? My FMP24-CC.bat is FMP24 -rc -i1 -o20001 -P0.0 -f774.78125 and my 1R.bat is DSDPlus -r1 -T -E -Pwav -i20001 >>1R-log.txt
slicerwizard
Toronto, Ontario
Just run the FMP24-VC.bat and 1Ra.bat files. Tune to the second control channel and off you go.
It's right in the Notes file:
If you have a second SDR device, you can run the 1Ra.bat file and the appropriate FMPx-VC.bat
file and simultaneously monitor a second trunking system or site or conventional channel(s).
To manually tune VC FMPx, press Esc once to take FMPx out of VC mode.
apx70001
Humboldt, IA
Slicerwizard, Thank you for the fast reply. Here is a screenshot of where I am now. Note there is no graphics in SDR #2 window
84884
apx70001
Humboldt, IA
got it fixed, I had to edit FMP24-VC.bat from -rv to -rc to monitor a second control channel. Thank you guys for your input
