help FMP-MAP location
Va2bsl
how i can change my location . its doesn't work is not the same think
thewraith2008
Get in your car and drive somewhere that isn't where your currently located. :ROFLMAO:
The files you are showing FMPA.cfg and FMP.cfg which can also include FMP24.cfg, FMPP.cfg use the 'search distance' and 'search origin' to display frequency details from the database 'FMP-FreqList.csv' that are in a radius of 99.9 miles ('search distance') from your defined location 'search origin'.
Use the file that is for the SDR you are using.
  • FMP.cfg - RTL SDR - Only use if using the public release of DSD+
  • FMP24.cfg - RTL SDR - Only use if using the fastlane release of DSD+
  • FMPA.cfg - Airspy R2/Mini
  • FMPP.cfg - RSP1(A) - Only use if using the fastlane release of DSD+
DATA points from received LRRP/GPS decoded by DSD+ are added to DSDPlus.LRRP.
You are either not receiving these LRRP/GPS or your radio is not sending updated GPS location.
If the latter is true, check the DSDPlus.LRRP file to see if same entry keeps been added. This may indicate issue on radio side.
If you have DSD+ fastlane, don't use FMP as the LRRP from fastlane version may not work well with it.
wgbecks
NE Wisconsin
You need to edit your FMPx files and change the "Search Origin" coordinates to match your location. Assuming your located
in Blainville, QC per your information in QRZ, then you would input: 45.6687 -73.8922 into the respective FMPx files.
