Help for someone that has no clue what they are doing
bruty
Saginaw, Mi.
Ok I have a Home patrol. I am not picking up police,fire, med. nothing. I am not very knowledgeable about what I am doing. Can someone help.Thanks Judy
kb8rvp
Michigan
Might be able to help but the Home Patrol isn't the best scanner for Saginaw because of the simulcast but may be able to help.
Mike
jaspence
Michigan
HP1 not picking up
Make sure you have updated your database as most of Michigan has rebanded. Simulcast should not be the cause of the problem although it may not always be received clearly. The other possibility is that what you want to hear has gone to encryption.
W8RMH
Feed Provider Since 2012
Make sure you have the "range" and "service type" settings set correctly.
