Help for Unication G4 Newbie
jsb1964
Farmersville, OH
I live in the Farmersville area of Montgomery County Ohio. My (small) home area uses simulcast for fire and police communications. I have both the SDS-100 and SDS-200. I believe they are programmed correctly (though I rarely, if ever see my home area mentioned). My wife is awesome and she bought me a Unication G4 since the Farmersville FD uses it. Unfortunately, I have found that programming it is a chore. Even with the ability to use RadioReference to import frequencies, I am having no luck. I am aware that the G4 is a pager that is used to monitor. I would appreciate any assistance to get it up and running.
Thank you!
kb9klc
I found a site in Montgomery CO that's listed as Dayton. Looks like it will cover your city. It appears there's a boatload of things In that county alone that's open and ready to be received. What part exactly are you having problems with on the G4. Are you actually receiving things on the SDS scanners and your area not being mentioned or are you not hearing it period.
jsb1964
Farmersville, OH
Thank you for replying! I think my issues begin with not having the correct frequencies for my Unidens (which I brought in via RR for the G4). My home and nearby fire/pd are dispatched from Englewood. I have the the Marcs frequencies programmed, as well as the local ops channels. I realize that this the town is small as well as the surrounding area, but I'm not hearing anything specific locally and I never see any traffic on my local frequencies on either scanner. As far as the G4 goes, those frequencies aren't doing anything.
According to the notes in the RR database, "The only fire departments in Montgomery County remaining on VHF are Farmersville and New Lebanon." So listening to MARCS wouldn't bring in comms, and a G4 won't work on VHF. Be sure the TAGS are active in the SDS (see far right below).
As for law enforcement they would either be on MARCS tower 1-005 Dayton or 4-003 Montgomery, I'd try both. The talkgroup shows they aren't encrypted, so just be sure you have all the proper TAGS turned on in the SDS scanner (Law Dispatch, Law Tac, etc) which you can find in the database on the far right.
151.385150.805KQF357RM141.3 PLNW MontCo Fire Farmersville FD/New Lebanon Fire (Dispatched by Northmont) [input tone is 203.5]FMNFire Dispatch
151.385153.770KQG229RM141.3 PLFarmersvl FireFarmersville Fire - Operations (Input tone is 203.5 PL)FMNFire-Tac
154.190 KQG229BMCSQFarmersvl FTacFarmersville FireFMNFire-Tac
@jsb1964 I will recommend you click on the REPORT button lower left corner of your first post and ask this be moved to the Ohio forum where there may be people in the area who can help you more. Also in the future if you have a question about the G4 it should go in the UNICATION forum.
Please do not start a new thread in the Ohio forum, the mods will be happy to move this, and double posting is discouraged in the forums. Good luck
