DSDPlus Help. How to submit a dsd+ requirement.
CaptainNemo
Genoa, Italy
Hallo everybody.
I need help to submit my little requirement for dsdplus fastlane.
I'm not found of these "social tools"...
Thanks in advance.
I want to share this req.
I'm still in the phase of searching and qualifying radio network in my area. So I skip from a freq to another as I see a strong signal.
It will be a big help to log the message shown in the bottom of the event log window along with other timestamped messages.
The message should be logged:
-- case a) when the "type" changes (let say I was listening to DMR and now on an other freq I get NXDN)
-- case b) when the color changes (let say DMR dcc:7 and now it is DMR dcc:1)
Thank you all
73
IU1MRD
gueta
Those get logged in the DSDPlus.event log, not sure if it is required but add -
Code:
-v4
and
Code:
>>DSD.log
to your command when starting DSD+
CaptainNemo
Genoa, Italy
Thank you very much for your reply and your suggestion.
I usually run with -v2 so I tried -v4
Unfortunately this did not work for me (meaning: I did not get the string logged, nor in the video, nor in the event log).
I will try again.
Anyway thank you.
bye
gio
