Help I really love this radio stuff just getting into it I need to find someone else that lived in Towns County and can help me understand the nxdn an
Tbwooten3
Towns County ga
trwmodela I've been reading alot of your post can you help me understand a few things I can't get enough of this radio stuff just getting into it need help and the know how for software what radio scanner to get and I've got an sdr ltr but really have lil to no clue how to use it... Someone please school me names Brandon but... Thank you
ecps92
Taxachusetts
Click on the Link in your original message on the left side, where it says "REPORT" and ask the MODS to move this to
your State/Regional forum, you will likely get more LOCALS there
ecps92
Taxachusetts
That web site is just an FCC dumping ground.
IT can only advise you that an FCC license has one of the digital modes as part of the license.
None of that actually means they use that mode, just licensed for it and we have seen agencies/business' etc
list every possible mode and only use Analog
True confirmation and identification falls onthe local listener to OTA (Over the Air) confirm the info and then make the submission to the RRDB
https://digitalfrequencysearch.com/Search/NXDNdisplay.php is this up to date? I've Ben doing alot of research on frequencies
Tbwooten3
Towns County ga
What's a good radio that's affordable to scan digital nxdn truck and analog I've got a sdr ltr really hard to understand the DSD+ and untrunker.... Is there one under 150$
Tbwooten3
Towns County ga
Thank you so much for your time! Really interested in this stuff wish I could have someone really show me the ropes with all this..
tvengr
Well Known Member
Baltimore County, MD
The least expensive scanners for NXDN are the Uniden BCD325P2 handheld and the BCD996P2 base/mobile. Both require the NXDN paid upgrade. You can install the upgrade yourself and save money rather than have the dealer do it. Unfortunately, there is no free programming software for those scanners that supports NXDN. The Towns County radio system is not that large and can be programmed manually using the scanner menus.
mass-man
trying to retire...
Parker Co., TX
I just programmed my new 996P2 with ProScan after the NXDN upgrade. But I have to take the radio to work tomorrow to test if it works. No NXDN near me at home!
ProScan is free for the first 30 days for you to learn and see if it's right for you.
tvengr
Well Known Member
NXDN works great on my BCD996P2 with the upgrade. I have the DMR upgrade also and both work well. Which NXDN systems did you program into your scanner?
N8IAA
Fortunately, GA
No scanners that inexpensive to monitor NXDN.
You have the setup to monitor NXDN. Towns has conventional NXDN repeaters. No trunking involved.
Nchpiboy
Hayesville, NC
@Tbwooten3
I'm over near you in Clay county NC and I use the BCD325P2 with NXDN upgrade to monitor Towns county. I program with Pro-Scan software. This was the least expensive option for me to get back into scanning. Others are using NXDN radios:
All Union county public safety
Clay county public safety
Union county schools
Blue ridge EMC
Tri-State power
Rabun county police
It was worth the upgrade price for me.
Tbwooten3
Towns County ga
Y'all this blog thing is all new to me y'all are the best I'm All over it thank y'all and the antenna I have for my cb is a 10 foot whip steel I need to upgrade badly have y'all looked into under 50$ range but need something that's kinda tall I'm in a valley.. any answers greatly appreciated!!
Tbwooten3
Towns County ga
@Tbwooten3
Blue ridge EMC
Tri-State power
Rabun county police
Is there anything ANYTHING CHEEPER or comparable like in 100$ range under 200$
Tbwooten3
Towns County ga
Okay so my main question now is nxdn conventional repeaters how do I listen to that either on a SDR or on one of those digital scanners y'all recommended
Nchpiboy
Hayesville, NC
I have never used any SDR devices. Hope someone will see this post and chime in on them. With a NXDN enabled digital scanner you only need to enter the frequency and the Radio Access Number ( RAN ) code to monitor.
