Help Identifying this Motorola radio...
Clovis, CA
I'm working on a history project for our department. Can anyone tell me what model portable radio is shown in this picture? Thanks in advance!
GTR8000
NY/NJ Database Guy
BEE00
Looks like a UHF HT220 Slimline to me. The only other radio it could be is an MT500, but the tapered back I believe was only found on the HT220 series.
CCHLLM
Yep, definitely a single channel HT220 SlimLine (tapered back indicates SlimLine) and definitely not an MT500. The PTT switch config is the giveaway there and the 500 had an external accessory port above the PTT button. The stubby antenna indicates UHF band. I worked on those as a tech when they were new and they were great radios.
W2NJS
Washington DC
Looks like an SP model HT-220 slimline, UHF, single-channel, with what we called a "surveillance back." I can't figure out what the control on the top at the back was unless it was PL on/off rotary switch which was the way the 220s controlled the radio's PL.
petnrdx
Hudson, FL
It looks to me like the item on the back is the screw in ( threaded ) earphone jack "dummy plug".
The early HT220 earphone "jack" was threaded.
And they made a threaded "plug" with a plastic washer to make it water resistant.
It was metal and looked similar to the tapered VOL and SQL knobs. Just about a third the height.
Later the plug was just black rubber.
There was a special earphone plug that was threaded so you could not pull it out accidentally, but they were not common.
The plug only had maybe four or five "turns" of threading.
CCHLLM
There were some with a toggle switch in that hole, but it looks like the factory dummy plug that you mentioned. I still have couple of those plugs in the miscellaneous hardware jar.
