Help in Colorado Springs
sjbridges
I have a BCD396t and am tryinr to program the CSPD and EPSO. The database says the system type is "Motrola Type 11 Smartzone" with "Analog and APCO-25 Common Air Interface". I have tryed several system types with no luck. Also, it lists different sites and frequencies, how do I know which to program, or do I program them all? The Talkgroup IDs have "Hex" and "Mode"...Do I have to program them in somewhere and if so where???
I was so excited to get the scanner but and now so frustrated because I can not pick anything up. Any help would be greatly appreceiated.
Scott
sking128
Colorado Springs, Co
Scott,
I live in the Springs, but I use a PRO-96/PRO-2096. If you repost this ing the Colorado forum, there a lot of people that will help you.\
Steve
mpdonala
Colorado Springs
Help is here!!
Depending on where you want to scan you might have to set up for the entire city. I have not played with the 396 I do have and programed uniden's and radio shacks for the city. i know I had to adjust an audio stting on my 996 and 296 and 250 to work with the system when I get home I will look thru the manual and try to help you that away. If all else fails maybe we can meet up and we can get that thing working. p.s. are you affiliated with law enforcement in some way or the emergency services? Just woundering. Mark
sjbridges
Thanks guys, I would appreciate all the help I can get. I will re-post in the Colorado thread. Mark, I am a volunteer with the El Paso County Sheriffs Office and an ex-Air Force Security Policeman. I work on Peterson AFB.
Scott
mpdonala
Colorado Springs
Hi
Still am looking for your answer. What do you do for the county, if I might ask. Thanks I vol. to for a FD in the county.
