Negative, that does 800mhz which is required for Trunk Mobile Radio system in Nova Scotia but this scanner only does 800 itself, that means you will hear EVERYONE on the TMR without the option to lock anyone out so following a conversation will be next to impossible as there are hundreds of TMR users with the bulk being in HRM.
You need a Trunk Tracker.
Go to Ebay.com and type in "trunktracker scanners"
trunktracker scanners | eBay
If you want to listen to HRM Police, RCMP, DFO, DNR Conservation officers, then you will need to go a step further and get a DIGITAL Trunk Tracker. Any scanner listed as doing "P-25" or "APCO 25" is a Digital Scanner.
