Help - Local OEM - Mobile Radios in a Box for Portable EOC
KURT12520
Cornwall-on-Hudson, NY
Hello, I'm a local Emergency Manager in NY with $Zero financial support from my local government. Well I am fortunate to have been awarded a grant from a major corporation to create a Portable EOC for my community.
I have been given the following used Motorola Equipment, All One-Piece CDM1550s (1)VHF, (1)UHF, (1)LOW and (1) MA/COM/HARRIS M7100 One-Piece 800 EDACS Mobile. I am looking to mount all of these mobiles in a portable box/case for use at the EOC or in the field. Ideally if I had the budget, I would purchase a Trident Micro Systems POP (Portable Operations Package)...see attached for concept.
I am looking for suggestions or best practices:
-Mounting box or case for all 4 radios, power supply, etc
-AC/DC Power
-Portable Antenna for lowband 46mhz
-Going to try and get Sti-Co tri coupler for V/U/8 radios and interoperability antennae (1 mag mount, 1 tripod mount)
-Going to try and get Trident Micro Systems CommTac2 also to mount with radios
-Will need to operate inside building (makeshift EOC) and mobile in back of vehicle or folding table
Trying to build this is the most simple and cost effective method
I appreciate any suggestions you may have.
Kurt
DisasterGuy
Maryland Shore
As an EM, what exactly is your goal with this system? Are you looking to ensure that the EOC can communicate with all field units or are you looking to create an interoperability system for field units? If the latter, assuming you are a municipal EM, does a solution already exist at the county level?
I am in the process of building something similar using a VHF Orion, 800 Mastr III Repeater, 2 UHF CDM1550's with a RICK and a XG-100M as a system link radio. All will be contained in a small rack enclosure to be used as a field deployable channel stack for national interoperability channels. An ACU-M will tie them together and the whole package is being designed to go up in a FD tower truck or utility bucket truck.
As a basic concept I would encourage you to look at using a musician style rack mount road case for the enclosure and dual 30A power supplies in a rack panel for your power. For the antenna, look at the Laird multi-band http://www.tessco.com/products/displayProductInfo.do?sku=368700&eventPage=1 using a triplexer such as the Diamond MX3000N http://www.gigaparts.com/Product-Lines/Tri-Duplexers/Diamond-Antenna-MX3000N.html?gclid=CL7j-8KtirwCFVFk7AodPxsAPw.
It is pretty easy to rack mount the mobiles using a blank 19" rack panel and cutting it for each radio. You can use standard console radio plates from Harvis, Jotto, etc to provide a clean look and mounting ears.
KURT12520
Thank you for the reply.
At this point, I am looking for this to have the ability to communicate with units in the field and with the Trident CommTac2, have the capability of simulataneous transmit on all 4 radios.
Your systems sounds great! I just took delivery of the XG100Ms at Work (Fed Agency) (non-touch screen model) looking forward to programming them this week.
I would also like to have a deployable repeater for VHF, UHF, 800 to work on the National Interop Repeater channels - any suggestions for portable repeaters and duplexer issues?
DisasterGuy
Maryland Shore
We manage a regional interop network for VHF/UHF/800 national interop frequencies and use Mastr III repeaters for all channels and sites. For 800, the Mastr III with the smaller and lighter switching power supply is the way to go in my book. A good option for VHF and UHF is the Hytera DMR repeaters featured for analog only. They are small, light, inexpensive and available with internal duplexers. The only reason that our transportable system that is being developed isn't using the Hytera repeaters is because we run VHF simplex and I have UHF CDM's as well as a RICK on hand.
You will like the XG-100M. They are solid radios and very capable. Assuming that you are on an EDACS system, you do need to use the CH-721 control head as the CH-100 isn't supported for EDACS.
