I recently bought a 2015 Ford Transit Connect to work out of, I want to have an NMO base installed, and I'm not quite sure what would be my best choice as there are so many options. I spend a lot of time in the Vehicle and I want to get good quality and get the best reception possible. I have the ability to put my own connectors on the coax, and will probably prefer this so I can keep the length as short as possible. I'm also going to have the base installed by a local radio company, it should be pretty easy for them to do considering there is no headliner in the way.
Here is the criteria for the antenna,
My primary interest is the Railband 160-162MHz, but I do listen to EMS, Fire, and other stuff down in the 140-155MHz range. I also want to be able to receive DPU and ETO transmissions from trains which are 452-457MHZ so I'm thinking a dual band would be best.
I'd like it to be able to tilt over, sometimes I have to go into parking garages, or customers might have low branches over their driveway. Perhaps having a spring mount also would be good?
Thanks!
Thanks!
