Please tell me that you're joking regarding priority being a "feature request". As you well know, the scanners have a
Priority ID Scan option for trunked systems, including P25. That feature does not function correctly with P25 TDMA talkgroups. That is a
bug, not a "feature request", nor did you mention anything of the sort in your original reply to me.
Last evening I started to look for threads that had pending questions/issues. It became quickly apparent this was a massive task that could take weeks to complete, so I am asking for some help to identify threads that have pending questions/issues. For now, I would like to focus on issues such...
forums.radioreference.com
And since when is this thread about hardware issues only? Your very first post asked for "basic functionality" issues.
For now, I would like to focus on issues such as basic functionality of Uniden scanners (firmware update issues and major bugs), and would like to avoid (for now) service issues.
Anything that is not a current feature, or advertised feature, would be a feature request.
Priority ID SCAN might not work as you believe it does. What that means is that when scanning the scanner will favor priority TGs over others. I'm going by memory of what UPMan said on this, but I believe I stated that correctly. This could have been changed at some point, but I will find out for certain.
The manual is vague on this and does not reference any priority for P25 trunk systems. For trunked systems it says it works as I described above. From the manual: "Priority is checked in between transmissions, when the scanner is receiving the control channel, and during the channel delay period."
For Motorola systems (Type I/II) it does mention preemptive priority. But again, makes no reference to P25 let alone Phase II.
As such, not being preemptive priority is not a bug if I am correct in my description.
While I generally agree with you preemptive priority is preferred, I cannot arbitrarily change the specs based on the way we believe it should be vs the way it was designed.
Yes, I asked for all issues. I also stated that there would be a priority as I stated. I can gather all classes at once. I cannot task the engineers with fixing all the issues at once. Documentation is much faster than resolution.
Your quote is accurate. In the class of feature requests, it would be lower. If it is a bug (and I don't believe that to be the case, but I will find out) then it may be lower than other bugs.
Link to earlier in this thread where priorities are addressed (53 posts ago):
No "major" firmware updates in the near future for the SDS series? That depends how you define "near future". I am in the process of documenting things that need addressed currently. Those will need approved, fixed, tested, and then released.
And yes, that was clarified from your quote. More distinctions/classes were added.
If I find that preemptive priority was the design goal, the issue will move up to major bugs, but will still be lower on that list, but is the third area to be addressed, not the first where we currently are.
I have already reached out to the management team and others on this question. When it is clarified, I will post the info.
