Descriptions of what the filter settings actually do would be helpful.
That is being worked on, but I need details from engineering first to make sure I post accurate info.
I think that the biggest issues with filters, at least one that generates a considerable number of comments, is how to pick the best filter for a specific system. Of course, you can select "Auto" for the filter, and the scanner will try each variant. But that has a very negative effect on the scanning speed. Also, once it determines the best filter, and uses it for that pass, the next time the same system (and site) comes up in the scanning sequence, Auto again tries the various filters to see what works.
It would be better if the Auto function would remember what worked during the earlier scan, so that it is not reinventing the wheel every time. Having the 'best' choice saved for the next time the system comes up would be great, even if it only saved it during that session, even if (like a temporary Avoid), that is discarded after the scanner is shut down, then rebooted at a later time.
If there is no way to save it for use during the current scanning session, i.e. a 'permanent save' is not possible, then is there a way to have the scanner display what was determined? We can update the display options to show what filter is set, and that will show up on the scanner as well as in the virtual control such as with ProScan. While the display will show "Normal", "Wide Invert", or whatever setting was in the Favorites list, 'Auto' continues to show 'Auto'. If that could be modified so that it displays what choice was made, instead of just 'Auto', that would be a very usable function.
