I am new to digital-era scanning. I grew up with a scanner on in my house 24/7, and I worked as a dispatcher for a couple of years after I graduated high school. I decided recently that I wanted to start monitoring my local police, fire, and EMS frequencies again (150 MHz DMR and 800 MHz P25 Phase I and II). I did my research and bought a Uniden SDS200, but I have problems receiving at my house. I’ve have tried the OEM rubber duckie antenna, the Remtronix REM-820S 800 MHz antenna, and the Diamond RH77CA 144/400 MHz antenna. I get about the same results from any of the three; I can/can’t receive certain frequencies depending on where I am located within my home or yard, even if I move a few inches. I can receive the 800 MHz P25 frequencies one minute, but not the 150 MHz. Then I move it to another spot and I can receive the 150 sites, but not the 800 P25s. I am pretty sure that I am a victim of topography. My house is in a low spot with 10-15 miles of hills and pine trees between me and the various broadcast sites that I am trying to monitor. I have decided to go ahead and setup a base station. I went ahead and bought an SDS100 to keep in the house, and now I am wanting to put up a mast-mounted antenna. I have an existing tv antenna mast that is 25-30 feet tall, maybe taller, and will require roughly 50 feet of coax. I have read and researched antennas, but I am just overwhelmed by the amount of information and the number of factors to consider. Could you guys please assist me in determining the right antenna for my situation?
