Help me please!!!!!!!!!!
drkngl417
West Plains, MO
I have just purchased my first scanner. a Rat shack pro 95. I live in springfield, Mo and I want to program my scanner to pick up the St. Johns EMS freqs. I am a EMT and would like to listen to calls off duty. Just checked out the RR datebase for my area but I don't understand the instruction book for programming my scanner. Could someone help or point me in the right direction of the proper information. Thanks :oops:
loumaag
Silent Key - Aug 2014
Katy, TX
I'll give it a shot here. All instructions refer to the system as described here on the DB.
First, pick a blank frequency bank on your scanner.
Program the 4 frequencies in red from the TRS entry here on the site as Motorola (MO) mode freqencies.
While in the program mode still, press <TRUNK> and cycle through the mode choices until it also is Motorola.
Once the mode is chosen enter TG 496 in. Press scan. If the display shows a "+" sign under the bank number, press <FUNC><5> to toggle to closed (a minus "-" sign).
Your radio should now only pickup the St. John's EMS. You really need to understand the manual so that in case you want to listen to something else you can program it in. :)
LarrySC
Greenville, SC
Better yet scroll down to your state forum. Post there with the same request. Could be a neighbor of yours has the program you need and even in a 95. Look for a local Guru. Clone a good program and give him a nice tip. Best way to make friend. Good Luck.
