im in hobbs nm and idk wich scanner to buy cuz i have one but i can oly hear prat of the calls im willing to spend 300................
You never really provided the make and model of the base unit you have, or whether you have an outside antenna. If you don't have a trunking scanner, you will not be able to hear
Hobbs / Lea County Trunking System If you have one, do you have this system programmed? This can be a bit over whelming to the beginner. Did someone program your base unit for you, or did you do it yourself?
I think you will need to tell us what agency(local police/fire/EMS or county police/fire/EMS) you only hear part of the conversations. If you have the trunking system programmed as a conventional(not trunking), you will definitely only hear parts of conversations.
As I mentioned in my previous response, you may be hearing only the base. Please try to tell us if you only hear part of BOTH base and mobile units, or just the BASE and not the mobiles.
Without a lot more details, we can't tell if you really need a new scanner, a better antenna, or just the correct programing.
