DSDPlus HELP: monitor 2 or multiple simplex freq No trunk
hamradionl
Hi all,
When start both DSD in there separated maps, all work fine no problem.
For hours i try DSD+ monitor 2 or more simplex frequencys Not trunk and use only 1x start .BAT.
Below only 1x DSD is completely start / running other one is start but not running.
Like ask your advice or hint or tip
i missing some setting, or not understand what iam doing, or where i go wrong, i dont see clearly what i am doing?
Try start both DSD using 1x start.BAT:
start X:\_DSD_A\FMP -i1 -o3 -P0 -g10 -wsl10.850 -f467.10000 -_1
start X:\_DSD_A\DSDPlus -fa -i1 -o1 -wsl10.10 -wss100.410 -wel140.10 -wes100.410 -wcl275.10 -wch17 -_1
start X:\_DSD_B\FMP -i2 -o2 -P0 -g10 -wsl250.850 -f467.20000 -_1
start X:\_DSD_B\DSDPlus -fa -i3 -o1 -wsl10.430 -wss100.410 -wel140.430 -wes100.410 -wcl275.430 -wch17 -_1
morfis
Check the input / output of each pair. It's confusing as you don't have the pairs set up together but one DSDPlus doesn't get an input?
This is what you have
_A\FMP -i1 -o3
_B\FMP -i2 -o2
slicerwizard
Toronto, Ontario
He's running all four programs in the same folder, so both copies of DSD+ try to write to the same DSDPlus.event file, and the second copy loses that battle, so it aborts.
Also, he's using virtual cables to link FMP and DSD+, even though TCP linking is supported. Yuck.
hamradionl
Thanks for advice
DSD i use separate folders/maps/dir like this
C:\_DSD_A\
C:\_DSD_B\
I make new folder/map/dir
C:\_DSD_START
Only contain
start.bat
DSDPlus.event
This also not give 2x separate DSD+ running....
The actual thing to be done,
1x start.bat to run/start 2x or more DSD+ events in same time
These are the only 2 frequency's i monitor using DSD+
slicerwizard
Toronto, Ontario
You have copies of DSD+ installed in two folders, but you are running those copies in the same folder! That's why the folder now has a DSDPlus.event file...
hamradionl
Sorry iam little dom old men and lost track :)
Folder C:\_DSD_A\ contain DSD_467.1000.bat
start C:\_DSD_A\FMP -i1 -o20011 -P0 -g10 -wsl250.850 -f467.10000 -_1
start C:\_DSD_A\DSDPlus -fa -i20011 -o1 -wsl10.430 -wss100.410 -wel140.430 -wes100.410 -wcl275.430 -wch17 -_1
Folder C:\_DSD_B\ contain DSD_467.2000.bat
start C:\_DSD_B\FMP -i2 -o20022 -P0 -g10 -wsl10.850 -f467.20000 -_1
start C:\_DSD_B\DSDPlus -fa -i20022 -o1 -wsl10.10 -wss100.410 -wel140.10 -wes100.410 -wcl275.10 -wch17 -_1
Like to start both Folder C:\_DSD_A\DSD_467.1000.bat + C:\_DSD_B\DSD_467.2000.bat
Using C:\_DSD_START.bat
Or any other way if possible
Thank you for help
slicerwizard
Toronto, Ontario
cd C:\_DSD_A
start FMP -i1 -o20011 -P0 -g10 -wsl250.850 -f467.10000 -_1
start DSDPlus -fa -i20011 -o1 -wsl10.430 -wss100.410 -wel140.430 -wes100.410 -wcl275.430 -wch17 -_1
cd C:\_DSD_B
start FMP -i2 -o20022 -P0 -g10 -wsl10.850 -f467.20000 -_1
start DSDPlus -fa -i20022 -o1 -wsl10.10 -wss100.410 -wel140.10 -wes100.410 -wcl275.10 -wch17 -_1
hamradionl
@slicerwizard,
ai ai when see it, you know it, at some point in age, start forget thinks
Thank you, we friends for ever.
Send me your paypal you buy nice piece of cake :)
These 2 channels only ones i receive in area 30-40 km, others are moved to tetra.
hamradionl
DSD+ Free version
FMP + TCP = working
FMPA Airspy-mini + VCaudioCable = working
FMPA Airspy-mini + TCP below setting, not see audio in DSD+ Audio Source
What do wrong?
start C:\_DSD\FMPA -o20011 -L7 -M7 -V7 -wsl10.10 -f467.00000
start C:\_DSD\DSDPlus -fa -i20011 -o1 -wsl240.10 -wss60.512 -wel330.10 -wes110.512 -wcl470.10 -wch22
slicerwizard
Toronto, Ontario
It looks like the FMPA 2.7 on the dsdplus.com website was for Fast Lane at some point. Not sure why it's there. I don't think it'll work with DSD+ 1.101 and Fast Lane FMPA is up to 2.35 now. Try using FMPA 1.02 with DSD+ 1.101
hamradionl
@slicerwizard,
i download the files from DSDplus website, iam not get TCP done combination with FMPA
When use the same setting in FMP, all working.
Change the TCP to 20011, 20022, 20033 not help
FMPA
See this: Listening on TCP port 20001
CC DSD+ see below
Initiating TCP connection to 127.0.0.1:2001...
TCP connect error = 10061
[No connection could be made because the target machine actively refused it]
slicerwizard
Toronto, Ontario
The Airspy Mini was introduced in mid-2016. FMPA 1.02 has a file date of January 2016, so the Airspy Mini didn't exist when FMPA 1.02 was released, so FMPA 1.02 isn't going to support an Airspy Mini.
FMPA 2.7 is a Fast Lane version, so it isn't going to TCP link with DSD+ 1.101
