Help!! Nac Conversion
Im not familiar with this NAC stuff. All I want to know is what do I need to program into my BCD 996t to listen to the following:
West Fargo, City of
Frequency Input License Type Tone Alpha Tag Description Mode Tag
154.28000 158.94000 WQCS575 RM 078 NAC WFGO FIRE West Fargo Fire P25 Fire-Tac
Any help would be greatly appreciated.
Thanks a lot
mikewazowski
Staff member
Forums Manager
Oot and Aboot
It's easy.
The BC996T does not do NAC so don't worry about it.
Thanks Mike but isnt there a way to convert NAC to hex or decimal to be able to listen? Im guessing just listening with open squelch wont do the trick either huh?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No, NAC is similar to CTCSS or DCS on analog.
If your radio is not equipped to handle it, then you can ignore it.
Since your 996T does not support NAC, it's basically operating in carrier squelch mode for all P25 digital signals.
If your radio did support NAC, then you could use it the same way you use CTCSS or DCS on analog signals.
Bottom line, just program in the frequency and forget that the NAC even exists.
