Help needed with the BCD396T
n8qxb
I've programmed the scanner for a APCO-25 system. http://www.radioreference.com/modules.php?name=TRSDB&sid=852
After, programming the frequencies using the Mot setup the scanner does not stay on any frequency long enough to track anything. I receive the signals but it continues scanning.
Something I'm doing is incorrect. The system hold time and the channel delay time are both set for 2 sec.
Any help would be appreciated.
73's
Tom
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
Check your programming and make sure you programmed the System as MOT 800 STANDARD, not MOT P25.
HTH's
73
Dave AKA The Tripzter :shock:
n8qxb
Hi Dave
I have it set to Mot P-25 If you click on the url in my post it shows it as a APCO-25 system. If that's correct then I have it set right.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
It's not a true P25 trunked system as it has analog and digital talkgroups.
Basically it's an old Motorola Smartzone system which uses P25 standard modulation for it's digital talkgroups.
Set your radio to MOT 800 Standard and it should work fine.
n8qxb
Ok, I will give it a try.
Thanks again for your assistance!
73's,
Tom
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
n8qxb said:
Hi Dave
Uh, no. The RRDB indicates this system is 3600 Mixed Mode, Analog or Digital Voice. MOT P25 is used for 9600 BPS PURE DIGITAL SYTEMS. You cannot use the MOT P25 setting for 3600 Systems, even if all voice is digital.
Try the MOT STANDARD Setting and let us know if it works.
73
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
n8qxb said:
This is confusing, cuz I don't see any reference in this system to Fleet maps which Mot standard 800 is asking.
Disregard the Fleetmap. It is a MOT TYPE II System. No need to go into Menu for FLEETMAP. Just Set the system as MOT STANDARD, Program the frequencies, and if you wish, you can set it to Control Channel Only Mode.
73
n8qxb
Hurray, it works!!!! I did what you suggested, changed it to MOT standard and now it works perfectly!
Thank you very much and have a safe 4TH of July Dave.
Tom
