moonbounce
- Joined
- Nov 5, 2002
- Messages
- 1,422
I was having computer issues and had to return my computer back to the factory default settings. So now I am starting all over again. At least now I have a clean hard drive.
Anyways the problem, I downloaded DSDplus as I did before resetting the computer back to the factory settings, I extracted it to a folder in my C drive. Next I downloaded Lame as before and ran it from the download folder into the DSD folder, no problems.
When I run DSD, instead of the clear Apco 25 decode that I had before, I get the clear audio plus the digital noise plus a sound like the squelch is too high. Is there a switch in DSD I need to adjust?
One other thing I noticed, I can't make changes to the DSDplus from the folder in my C drive, I have to use the command prompt, run DSD and I can make changes from there but those changes are only good as long as I run the program from the command prompt. The changes I make while running DSD from the command prompt ( eg. -v3 ) will not stay when I run DSD from the C drive?
Any help would be appreciated.
Moonbounce
Moonbounce
