Help neededI messed up My Maxtrac. Its a D33MJA7DA5CK
I was programming my maxtrac's and since most all are the same I read the codeplug data, changed the frequencys and stuff, and plugged each one in and programmed data to each radio. They were all 5 pin logics... then i came across my 16 pin logic board radio (D33MJA7DA5CK). I plugged in my radio and programmed it. Then realizing i screwd up Because this was the 16 pin. The Radio turns on but nothing displays... I can still read and Program Data
How can I go about fixing it?
b7spectra
EMS Dispatcher
Cobb County, GA
Easiest fix would be to take a code plug of the same model and dump into it. Check your files to see if you have an original from when you first programmed it. If for some reason your radio became a brick, they are very inexpensive on eBay.
Thats what I was thinking I would have to do
But I Fixed it. I figured out that when I loaded the 5 pin logic boards codeplug data into the 16 pin radio, it didnt work because it actually loaded the Logic data and not just the frequencys and such...
What I did was I blanked the Logic board and entered the correct data. It is now back to normal
It was an easy fix. took about 5 Minutes
Now i can reprogram my Frequencys
zz0468
Banned
And hopefully you learned that you always back up your original codeplugs and keep them in a safe place.
