help on new freq
landlord2see
callao ,va
i have a pro 99 and i havefive banks almost filled with f&r,pd from va &maryland i want to fill up the rest any suggestion would be helpful ilive in the northern neck,but i canpick up alot :?: :D
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
Naturally, you'll want to put in all of the agencies from the Neck, plus Calvert, Charles, and St. Mary's Counties in Maryland. Keep in mind that 80% of what you can receive is based on the antenna. If you're using the stock "rubber-ducky" antenna that came with the scanner, you're going to have limited reception, espically on the low-band frequencies.
Since you're near the water, you might try:
Virginia Department of Game and Inland Fisheries
Virginia Marine Resources Commission
United States Coast Guard
The standard marine channels
Don't forget the MSP helicopters!
Hope this helps...
