Auren
Do you have the BC 246T or 245. The 245 will do EDACS. In any event- if you have 2 scanners here are two files I've been saving about how to determine LCN. It takes a bit of work but maybe you can work it out:
file #1
Third hint, this one will allow you to easily figure out LCNs for Edacs
systems. Edacs systems can use up to 25 LCNs. The 245xlt doesn't
seem to be concerned with the current LCN slot for the active
Data-Channel, so put the currently active Data Channel into one of
the last five channels in the Trunk Bank. I recommend the last one, if
its blank. Now switch up to LCN1. Get another 800Mhz scanner, and
get an accurate list of frequencies for the system in-question ; This is
very important. Starting with the first frequency, put it into your 245xlt
into LCN1 & into your other 800Mhz scanner, now press the 'SEARCH'
key to acquire the Data-channel. Listen to both scanners. If both
scanners don't mirror the same audio at the same times, then zero-out
LCN1, and put that frequency into LCN2, and try again. Use this
proceedure til you have them all. You should only have one LCN left,
the LCN for the Data-Channel. If you have more than one LCN left,
then its possible that the extra LCN is disabled because its been
reallocated or the repeater might be in the-shop for service. To figure
out which of the remaining LCNs belong to the currently active Data-
Channel, wait for it to switch the Data-Channel over to another repeater.
Then, program the previous Data-Channel's frequency into one of the
empty LCN slots of your 245xlt & the other 800Mhz scanner.
If both scanners don't mirror the same audio, then try one of the other
empty LCN slots until you get it. This proceedure might take sometime
to complete. It is the, 'Process Of Elimination'. Its the best way to get
it figured out.
File #2
Using this system as an example
935.1375
937.6750 <CONTROL CHANNEL>
938.9000
939.4125
939.9125
For EDACS systems, the easiest way to determine LCN is to put the
control channel in a higher channel in the bank, then enter each voice
frequency into every channel until you nail which LCN it is in.
For example: use Bank 1 for this EDACS system, which has 5 frequencies.
Place the control channel (937.675) into channel 6 or higher (why?
Because you are trying to determine LCN order, you do not want to take
the chance of putting the control channel into a voice LCN). The scanner
does not care what channel the control channel is in, only the voice
channels (and make sure you enter them in trunking mode).
Now, place 935.1375 into channel 1, 2, 3, 4, and 5 and begin tracking
the system. As soon as a talkgroup with voice activity pops up on the
scanner, exit trunking mode, and the scanner will be on one of these
channels, which will be the correct LCN (i.e. let's suppose for this
example that the scanner is on channel 2 as soon as you exit trunking
mode, you know that 935.1375 is LCN 2).
Now repeat these steps for the next frequency 938.900, but this time
enter it into channels 1, 3, 4, and 5, and enter "0" into 2 (again, for
example we are assuming we already found LCN 2). Enter trunking mode
again, and when a talkgroup pops up again, exit trunking mode and note
which channel the activity was on.
Continue this process until you determine the LCN for all of the
frequencies, and by process of elimination you will find the correct
order of the voice channels. The control channel, however, you will not
know which LCN it is until it changes to another frequency and you
repeat the process.
VERY IMPORTANT - this method assumes the system is using sequential
LCN's, i.e.
LCN1
LCN2... all the way to
LCN5
BUT some systems will "skip" LCN numbers, i.e.:
LCN1
LCN4
LCN5
LCN7
LCN9
In other words, they could use the 5 voice frequencies you listed above
but give them non-sequential LCN numbers. If your system is like this, I
would then place the control channel into channel 26 (since EDACS
systems have a limit of either 20 or 25 channels) and do the procedure I
listed above, but enter the voice frequency into maybe 10 channels at a
time.
The best way is to run ETRUNK on the system to see which LCN numbers
exist on the system, then use the above method to determine which
frequencies pair up to each LCN.
Rickey Stein
