rescueric
I have a pro 528. I turn it on andf it scans for a few seconds, then it goes dead. Everything quits. Can anyone help me?
OK, Here comes a stupid question, when is the last time you put fresh batteries in the radio?I have a pro 528. I turn it on andf it scans for a few seconds, then it goes dead. Everything quits. Can anyone help me?
OK... I'll bite. If you turn the volume up does it magically get louder??I replaced the batteries and it works now, except for no volune.
I think is programming problem by user.Hey I have the same problem, but my can scann aviation frequencies, the 800MHz, UHF and VHF will scann but I can hear nothing.. The aviation frequencies they are load and clear, I think is software problem with the scanner,
Is there a mute function on the scanner? If so, is it set to "Off"?No it dosent. There is no sound at all.
So if you plug external speakers in, it works and you can hear transmissions? If it works that way and does not work when external speakers aren't plugged in, I'd have to say it is an issue with the internal speaker. Is it blown perhaps?I get no audio except through speakers.
You might be a REDNECK........... Good Job DAK48 LOLSo if you plug external speakers in, it works and you can hear transmissions? If it works that way and does not work when external speakers aren't plugged in, I'd have to say it is an issue with the internal speaker. Is it blown perhaps?
Did those comments make you feel better?You might be a REDNECK........... Good Job DAK48 LOL
Hey My TV won't turn on should I plug in this little CORD? lol My LAMP won't work unless I put another bulb in it what's the problem?
