You can put conv and mot in the same bank. But the bank must still be set to mot.HOLEBILLY said:I have programmed all the freqs i want to listen to from win 96 and all i can hear is the digital i programmed in. I can not pick anythink up in conv,and also can you program both mot and conv on the same channel?
State Please?HOLEBILLY said:Trying to hear Stark co digital and huron co conv
What county are you in, stark?HOLEBILLY said:sorry ohio
any at all?HOLEBILLY said:huron co but at night i can hear stark co, but the problem is i no longer pick up any conv freqs at all on my 2096
If you are using Win 96 to set up your scanner it should look something like this if you wish to mix convetntional with Trunking. This is just a sample I made up with web import.HOLEBILLY said:huron co but at night i can hear stark co, but the problem is i no longer pick up any conv freqs at all on my 2096
Nice example scnnr, my bet is HOLEBILLY has all freqs set to MOT. Web Import neatly resolves our errors.scnnr said:If you are using Win 96 to set up your scanner it should look something like this if you wish to mix convetntional with Trunking. This is just a sample I made up with web import.
Could you possibly zip up your p96 file that your scanner is programmed as now and upload it to here so we can take a look at it? Maybe one of us can see if there is a problem with that.HOLEBILLY said:I put all conv freqs in one bank and set it to conv and still cant pick up anything. Cant even pick up weather . I use to pick all these freqs up,dont know what happen
I do it with mine all the time. Seems to work fine for me. I try to use my banks set for differant counties so when I travel I just drop them in and out.lsh1885 said:Technically you can, but it is my experience that it is better if you don't, if at all possible. My opinion for whatever thats worth.
