Help Program Atlantic City Pd Trunked
captmcl1
I have recently received a PSR 500 and am having trouble programming the Atlantic City PD trunked system. Can't get it to work. This is after reading directions quite a few times. I am not sure where to enter which parameters where after creating the trunked object. Right now I have TSYS as P25 Auto, tag ACPD, ID 12224, type group, tag ID wildcard. Took the info from the database here. They are about 20 miles away so I should here them, as I receive other conventional stations even farther. I am finding the learning curve on trunked systems difficult. Have had conventional scanners for years, life was a lot simpler. Help please.
captmcl1
RE: Atlantic City, NJ PD
just want to add I have also programmed in the primary and alternate channels listed for the system. Thankyou
lowboy654
DB Admin Member
Northwest, WA
Welcome to your new scanner and here to, you have bought a great scanner one thing i would do if where would be to download a software program to help you program you scanner.
http://www.starrsoft.com/software/win500/default.asp
http://www.butelsoftware.com/
your scanner should have came with a USB programing cable the above software is free to use for 30 days and if you get a Premium Subscription here you can do a web import and you will be up and running in no time at all, if not I would down load the free software and use it to program your scanner
and one more thing you can look in your state forum here and find a lot of help there to.
http://www.radioreference.com/forums/forumdisplay.php?f=52
