help programming a MOTO Maxtrac 16 CH UHF
W1CRN
Liberty, SC
Wirelessly posted (BlackBerry8530/5.0.0.886 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
I have a motorola maxtrac 16ch UHF radio, the dos program for it and the cable. I also have a computer running dos. The question is do you have to put the radio into a programming mode like some other radio? And if so how do you do this. Any help would be great. Thanks
davidgcet
no, the maxtrac just hooks up and reads. your software has to be as new or newer than the firmware in the radio, and unless you bought a ribless cable you need a rib box. you also need a real comport, not a USB com port adapter as they don't work in DOS.
W1CRN
Liberty, SC
Yeah I bought the ribless cable. Thanks I will try it when I get home tonight. Hope it all works.
davidgcet
if it won't read, go under F9 computer setup and change the speed. i forget the exact term, but it is to change how fast the computer tries to talk to the unit. usually slowing it down corrects read/write errors. i've used the Maxtrac software with everything from an old 8088 to a 1.2ghz machine, ideal operation is a 286 or 386 machine but any of them will work so long as it is true dos and not a window.
b7spectra
EMS Dispatcher
Cobb County, GA
A rule of thumb for Motorola programming:
If it is a DOS based software (MRSS), use a SLOW computer in DOS (not a dos window or shell).
If it is a Windows based software (CPS), use a Windows based computer (speed really doesn't matter).
