Help programming Pro 96 and pro 2096
Hagerstown, Md
I have been attempting to program a Pro 96 and a Pro 2096 using both Arc 96 and now trying Win 96. Trying to install Washington County Md and Jefferson county WV both are P25 trunked and when I use the data from radio reference I get nothing scannable on scanner.
I have used Arc before to program psr 500 and never had any issues. Im new to this and could use any advice.
lou9155
shamong nj
try manually programming your control freq. and see if you hear the digital noise....my pro2096 recieves off freq in the 800mhz band...g g communications couldnt fix it and yes im very frustrated
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Do some homework - there's been numerous threads here about making adjustments on both the 96 and 2096 to realign the 800 Mhz performance. Use the SEARCH feature which appears right under the thread title. However neither system is on 800- they're both UHF
For Washington County, there's a custom table you need to put in, according to the database entry...
https://www.radioreference.com/apps/db/?sid=6451
See the Misc System Information section
Looks like Jefferson County (actually you want SIRN) also requires a custom table, and it's explained in the same area of the database
https://www.radioreference.com/apps/db/?sid=4076
There are 2 Jefferson County sites - one in Kearneysville, the other is Mount Weather. You may need a better antenna if you can't hear anything out of these sites
Specific questions on these systems should go to the Maryland and West Virginia forums, respectively.
I don't have these scanners - and they're very old anyway - but you should be good to go with this information...Mike
1605
Hagerstown, Md
Thank you I think I got it. I'm sorry I normally search for things but I didn't even know what to search for.
Tulsa, Ok
Is there any chance I could get the custom table information for the OKWIN (P25) system for Tulsa, OK?
I have this from a 3rd party, can it be converted into Pro96 language?
851.00625 00-000 00-4095 6.25 1
762.00625 01-000 01-4095 6.25 1
851.01250 02-000 02-4095 12.5 2
762.00625 03-000 03-4095 12.5 2
Thank you in advance.
