The FreeScan user guide is in the
Wiki.
The thing that usually trips people up trying to create a "P25" conventional system is the "view".
From the starting screen of FreeScan:
Either open your existing file that you want to add a conventional P25 to, or if starting from zero, click "File-New" (shortcut keys <CTRL> + <N>)
Now, click the "New SYS" button. That's on the top menu bar, just to right of the printer icon.
You'll get a dialog box asking of you want a conventional system, or a specific 'flavor' of trunked system. Choose conventional, and give it a name.
See
this page for step by step instructions, and screen shots. This is from the user guide.
You can then add groups to your system (the New GRP button on the top menu bar) if you want to spread them out, like a separate fire & police group. Remember that the text in the display will alternate between whatever you name the system, and the group name. The actual channel's text tag will be on the next line, and will not alternate with anything.
Note" Be sure to "uncheck" the box for "Simple View". That will expand out your channel editing choices, so that you can enter your NAC codes, if known, and set the display colors. See the attached file for a short P25 conventional file.
