ProScan HELP! SDS200 Over LAN to ProScan "Disconnecting"
mattmac553
I have my Uniden SDS200 plugged into a TP-Link N300 for connection to my network, and ProScan on my Dell. The channel history and remote display work fine, but as soon as I connect all the audio to the URL mode on ProScan within a few minutes the screen on ProScan goes blank. My SDS200 is still fine on its own, but it needs to be restarted every time to reconnect to ProScan. If I don't connect the audio through URL it runs fine.
To replicate
1) Connect SDS200 to internet
2) Connect SDS200 comport on from scan to URL, and set IP
3) Connect audio via URL (seems to be where things go wrong)
Any solutions or possible fixes?
mattmac553
Also,
Can not reconnect without restarting scanner manually.
If I reboot scanner it comes right back up on ProScan with out needing to do anything on computer.
mattmac553
Solved! I ran a 50' cat-6 cable to my router, and got rid of the TP-Link. Working like it should.
