Help Selecting/Locating 700-999.990 MHz Frequencies (FM) to Scan on my Yaesu FT-60R
KC1THE
My FT60 can Rx 700-999.990 MHz Frequencies (FM) - but w/blocked cellular - and am looking for some sources to monitor.
I found this page to monitor some 700 MHz frequencies but cannot find anything else. Appreciate an help you can provide.
I am also finding some FM modes in the above frequency range arrayed across the various categories here:
I'll keep looking...
It's really going to depend on your location.
There are analog users on 800MHz. But it's not as common as it once was. As time has marched on, many have gone to digital modes. There are some business allocations in the band, as well as public safety.
700MHz is going to be mostly P25.
900MHz is changing fast with Anterix buying up a lot of spectrum and building out there LTE system. Searching the FCC database for your area might give you some clues, but mostly those will be trunked systems.
You could try programming in the 800MHz NIFOG frequencies, but usage really depends on location.
KC1THE
This is very helpful. Thanks. I did notice a lot of P25 in the 700 MHz range. I’ll keep hunting around.
garys
Texas
Marlboro MA PD and FD were on 800 conventional analog the last time I looked at it. Sudbury PD is 800 conventional P25. There is a small group of 700Mhz conventional analog frequencies that someone mentioned a while back. 900 is going to be digital of some flavor or another and also probably trunked.
W1KNE
Owner ScanNewEngland
New England
Okay, so another option for you would be the analog voice channels of the MSP trunk .
Marlborough is going P25 in the not too distant future.
KC1THE
Ok thanks. I found several 851/853 conventional channels here:
I’ll program those in.
Found four more in Worcester and will try those also and see what can pick-up:
Worcester​
Commonwealth Of Massachusetts Interoperable Radio System (CoMIRS)
Project 25 Phase II
Worcester Public Safety has migrated over to this system, the EDACS system is no longer in use.
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
460.050KJR698RM051 DPLWorcFD OP-CFD Fire Ops C (Patched to 4439)FMNFire-Tac
769.00625WQFN732M799 NACWorcLCFG-P25Local Fireground - P25P25Fire-Tac
769.00625WQFN732M131.8 PLWorcLCFG-AnaLocal Fireground - AnalogFMNFire-Tac
769.01875WQFN732M799 NACWorcFD OP-DFire Ops D FiregroundP25Fire-Tac
769.03125WQFN732M799 NACWorcFD OP-AFire Ops A FiregroundP25Fire-Tac
769.04375WQFN732M799 NACWorcFD OP-BFire Ops B FiregroundP25Fire-Tac
859.4875WPKI790RM799 NACWorc RPT1-P2Fire Repeater 1 - P25P25Interop
859.4875WPKI790RM131.8 PLWorc RPT1-AnFire Repeater 1 - AnalogFMNInterop
855.9875WPKI790RM799 NACWorc RPT2-P2Fire Repeater 2 - P25P25Interop
855.9875WPKI790RM131.8 PLWorc RPT2-AnFire Repeater 2 - AnalogFMNInterop
ecps92
Taxachusetts
Marlboro is going or has gone P25
The NIFOG 800's would be of some value for the OP, since they are mostly Analog, unlike the 700 that is mostly P25
And until the CoMIRS east of Springfield goes P25, they can also listen to the MSP Trunks (Analog) but won't know what TG is being heard
KC1THE
Thanks for this. I was also PM'd with those and will program the five 8 tacs in on Page 62:
  • 851.0125
  • 851.5125
  • 852.0125
  • 852.5125
  • 853.0125
ecps92
Taxachusetts
