Okay so I guess the people who came up with 'new math' also designed the interface for the 396XT. HELP!! This 'should' be easy but dang if I have been able to figure it out. I've tried the supplied manual as well as the one on-line. I'd like to be able to shut off talk groups or complete systems. The programming software allows me to set systems to the system numbers (0-99) for conventional systems but not trunked systems. So how do I lock out or shut off a trunked system??
Also when I turn on the scanner all 40 conventional systems that are programmed into the scanner are turned on. Is it possible to set the scanner so that say only systems 0 1 4 and 8 are live and the rest are off unless I turn them on? Going through and shutting off 30 systems every time I turn on the scanner is a PIA.
