Help setting up MTrunker32
Joseph11
Hello,
I've been trying to get MTrunker32 working for weeks, but have had no luck. I want it to decode a UHF Motorola Type II system through my Line-In port on my soundcard. I have my soundcard's recording device set as Line-In but MTrunker32 doesn't do anything. Also, the scanner is not tapped, but is there a way to see if I can do this without tapping it?
EDIT: Here is an audio sample of it, RARed: http://www.freewebs.com/filingeri/misc/control.rar.
DualC
Sorry, but u have to get a disc output from ur radio to get MTrunker32 to work, its no other way to make it work.. :)
Maybee, u can get a better result when Uni-Trunker lands here. I don't have a clue if u must have a disc output on the radio to make what software to ROCK..
/M
Joseph11
I looked all over the Internet for a discriminator tap mod. for both of my scanners, but found nothing. I have a Uniden Bearcat BC 175XL and a Radio Shack PRO-24.
loumaag
Silent Key - Aug 2014
Katy, TX
I don't know about the Bearcat one, but the Pro-24 apparently uses a MC3357P IC which according to the old Bill Cheek mod sheet should be tapped from Pin 9.
I don't know this to be correct information; all modificatoins made by you are your responsibility, not mine. :)
Joseph11
OK, I was looking at an older one (1996). Thanks.
