help setting up treeport
certifiedrss
san diego
i am attemting to set up treport in the place of my trusty etrunker program. can some one hel-p me with the initial set up. How do you get the program to toggle thwe different slicer pins?
certifiedrss
san diego
Ok Still Need Help
i GOT THRE PIN TO TOGGLE,BUT DO I NEED TO INPUT A C/C OR WILL IT DO IT ON START UP WHEN IT REC AUDIO FROM THE TAP
WayneH
Forums Veteran
Super Moderator
Your master site
What's your purpose for using TREPORT? You mentioned using it in place of ETrunk. ETrunk is for EDACS. TREPORT is for Motorola systems and is specifically for reporting background information. It's meant to show you information Trunker doesn't.
I'd recommend going with UniTrunker. I think it's more up your alley.
Also, the file TREPORT.INI is where you set up your physical hardware and settings. The CFG files are for configuring TRS specific information.
-Wayne
certifiedrss
san diego
Treport
You Are Right I Was Using Trunker Not E-trunker, Primarily I Just Wanted To Use The Software To Monitor Frquency Usage On Different Sites. I Did Get Treport Running, Where Do I Find This Software You Are Talking About.
Chris
