I've inherited a system of about 30 CP200's and 6 CP200d's at work, and am hoping to add a repeater to the system as we often have trouble hearing each other from opposite ends of the space (basement location with a lot of rebar in the walls). I'm putting together a cost estimate for the upgrade, and was hoping to have some assumptions confirmed, and few questions answered. And please tell me if there's a better solution than this!
For background, my CP200's are the 4 channel models, the first two we use constantly (two different departments), the second two are only used occasionally. The CP200d's are 16 channel models and are used by some of my supervisors (which works out, I could give them the talk-around frequency for if repeater goes down). We're currently in the 460mhz range.
To hopefully solve the reception issue, I want to get a repeater for the two channels we constantly use. As I need to keep the analog-only CP200's for at least a few more years, I'd be setting up at what I believe Motorola calls the "Single Site Conventional" system, where each channel is two frequencies and the radios TX on one to the repeater, and RX from the repeater on another. I've used (though didn't build) this type of system at a prior job with a fleet of HT750 and HT1250's.
Looking at repeaters on the Motorola site, it seems like the SLR5000 has a channel capacity of 64 and judging from the picture of the front panel, that it would be able to simultaneously act as a repeater for two analog channels in conventional mode. Is that correct? And that channels 1 and 2 could be used simultaneously? This is my biggest question/concern.
It seems like the SLR5000 does not come with an antenna or cabling, if that's correct what antenna would be recommended? I expect to place the repeater within about 10' of where I'd place its antenna.
Clearly I'd need to reprogram my existing radios. Would I need to buy three different CPS programs (CP200, CP200d, SLR5000), or just one? And how much (roughly) is a copy of CPS? I want to include that in my estimate and can't seem to find a price without bothering Motorola (which seems premature at this point).
Longer-term, I'm hoping to upgrade some of the CP200's to SL300's for the customer-facing employees. It seems like the SL300's could be programmed to work in conventional mode and join the system before I've retired the last CP200?
Hopefully I've written all of that clearly. I welcome any advice that could be offered!
