Help submitting Info
sirsmiley
Ontario
Ive completed a discriminator tap on a BC350C (no one has done the 350C before, just the A which uses a different chipset). I have taken photos but I have no idea how to submit the info. Can I send the info to one of you folks so you can add it to the wiki?
Thanks.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You can do this yourself. It's not nearly as complicated as some folks make it out to be
First to upload your photos. When you bring up the wiki, go down about 1/3 of the way to an area marked 'TOOLBOX'. You'll see a link there for uploading your photos. It's pretty self explanatory - just be sure to record the file names. You'll need them for the next step
Now click on your ID in the 'PERSONAL TOOLS' area. You're assigned a small work area (every ID has one). Here's where you can code and not disturb anything that's active.
Now to put the text together, and the command used for bringing the photos into your article, you can use the following article as a model....
BC796D Discriminator Mod - The RadioReference Wiki
Edit this, then copy (don't cut) this article into your workspace and make the changes you need. When you're ready to 'publish' let me know and we'll go through the next step
HTH...Mike
AK9R
Staff member
Super Moderator
Central Indiana
Looks good. Thank you.
