HELP this makes no sense
kmnewburn
plattsmouth ne
Ok I bought a husband a digital scanner for Christmas. I have no clue on any of this. I looked up and got a list of frequencies for our city. Now I don't know how to program the scanner. None of it, the backlight, etc. I need step by step instructions because the manual is too hard to understand. HELP PLEASE
04Z1V6
Castle Rock, Co.
This is some of the info needed : What make of scanner, what model of scanner, would you like to program by hand or with software, do you have a programming cable (may or may not be needed). Read the wiki and easy to read manuals by searching the interweb.
troymail
Silent Key
We're here to help!
Which model scanner?
Where are you located?
What does he want to listen to?
One additional key point.... play and learn before spendind a lot of time progrming it. At some point you can do a "factory reset" (or something like that) and then really program it.
I've gotten very frustrated in the past and learned from experience!
kmnewburn
plattsmouth ne
Bcd396xt. I'm located in plattsmouth nebraska 68048. he wants to listen to the fire, rescue, police in out town and maybe further out into Bellevue or sarpy county.
wtp
Port Charlotte FL
when new...
i am thinking the reason that we are getting no information is that she is new and is waiting for the page to reload by itself. a friend of mine thought this is how things work.
kmnewburn
plattsmouth ne
programming
It is a Uniden BCD396XT scanner, I am located in Plattsmouth Nebraska 68048. We want to listen to the basic fire, police, emergency in our town and then maybe surrounding cities, Bellevue which is Sarpy County Nebraska 68005.
kmnewburn
plattsmouth ne
My computer is older so i might have the right cable that came with the scanner but not sure. I have pictures I took of the back of my computer.
troymail
Silent Key
kmnewburn
plattsmouth ne
ok to start from the beginning.
press menu, then program system, select sys type, conventional hit yes. then it said edit name press yes, see entering text. LOST
So then we went down to this part:
it says set quick key, for no quick key says hit yes.
then set start up key, for no quick key hit yes.
set number tag, to default to no number tag press yes.
set lockout, we didn't lock out any.
set hold time and delay time we did the least amount of time.
set audio AGC we turned on analog and digital.
then the P25 wait time . that is were we stopped.
You figure for this much money, they would program it for you.
Piece of crap I think...maybe we should return it. too hard to understand all this set quick key, set start up key, set number tag, what is that all about?
russellmaher
Enfield, CT
It's a high tech unit and requires a bit of patience on your part. We will get you through this, don't worry.
Don't think of returning it just yet.
Russell
wtp
Port Charlotte FL
quick and dirty
to do it real fast try this
you can always go back and fill stuff in but for now
menu
program system
new system
conventional
confirm
edit group
new group
edit channel
new channel
input 155.49 (or more)
then just hit scan
evey thing else is to tweek the settings
if you want just input everything in the county to get going and you can delete it later
ok try it
